Help on logme.txt contents
Need some help figuring out what this means and how to correct the conexc.dll issue
*** Log Manager 0: Opened on: 06/08/2003 [19:22:37]
[19:22:37] COSIController:AttachFeature: no genUI interface, will load all OSIs
[19:22:37] COSIController::PaintCache failed to paint to screen
[19:22:37] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=12
[19:22:37] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[19:22:37] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[19:22:37] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[19:22:37] ResMngr::Command Line=/TV+ UIO Guid=
[19:22:37] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[19:22:37] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[19:22:37] TVUIO::PreStartUp - Optional ConO DV failed to load
[19:22:37] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[19:22:37] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[19:22:37] TVUIO::StartUp: Display ConO - Invoking Startup...
[19:22:37] Display::Could Not Localize RegPath for \Title
[19:22:37] CDispControl_DS:SelectDecoder: Name=ATI Rage Theater Video Capture Index=1
[19:22:37] CDispControl_DS:Setup: Starting with 2 Crossbars for Audio & Video
[19:22:37] CDispControl_DS:Setup: Preview Out is not available on Capture Filter
[19:22:38] CDispControl_DS:Setup: Starting up using Format Converter as Capture Tee
[19:22:38] CDispControl_DS:SetDefDispMode: Selecting Video Capture Display Mode: 0
[19:22:38] CDispControl_DS:SetBestCapture: Setting Capture Pin: 720x240 @59.94fps (165722112bps)
[19:22:38] CDispControl_DS:SetVBIFormat: SetFormat: 1 on VBI pin
[19:22:38] CDispControl_DS:SetVBIFormat: VBI pin NOT connected
[19:22:38] CDispControl_DS:SetVBIFormat: MediaType on VBI Pin: Standard Succesfully set to: 1
[19:22:38] CDispControl_DS:SetBestCapture: Best video quality disabled
[19:22:38] CDispControl_DS:SetBestCapture: Video Delay set to 0
[19:22:38] CDispControl_DS:Setup_LiveStdPerf: Rendering Live Video via VideoPort
[19:22:38] CDisplay::IsAlphBlendingSupported: 1
[19:22:38] COSIController::PaintCache failed to paint to screen
[19:22:38] TVUIO::StartUp InitDisplay Completed Succesfully
[19:22:38] TVUIO::StartUp: Video ConO - Invoking Startup...
[19:22:38] TvVideo: StartUp: Using DirectShow Drivers
[19:22:38] TVUIO::StartUp: Teletext ConO - Invoking Startup...
[19:22:38] CDrvTeletext_DS:GetVBITee: Sink-to-Sink Tee is already Present
[19:22:38] CTeletext_DS:Setup: Teletext To Closed Caption Filter is not Present
[19:22:38] CTText:: Teletext ConO Failed to initialize Driver
[19:22:38] TVUIO::StartUp on optional ConO TText failed
[19:22:38] TVUIO::StartUp: Closed Captioning ConO - Invoking Startup...
[19:22:38] CCaptionControl_DS:Setup: Connected WDM CC Decoder with ATI CC Renderer
[19:22:38] CCaptionControl_DS:GetVBITee: Sink-to-Sink Tee is already Present
[19:22:38] CCaptionControl_DS:ConnectTee: Connect Decoder with Tee
[19:22:38] CCap:Caption: Attempting to Load & Initialize Closed Captioning Drivers...
[19:22:38] CCap:Caption:Captioning Source has been STOPPED
[19:22:38] TVUIO::StartUp: Sound ConO - Invoking Startup...
[19:22:38] CSoundControl_DS:Setup: start OK
[19:22:38] NumAudioDrivers:found (int) 1 drivers
[19:22:38] CSoundControl_DS:RewireAudioCapture: Audio Crossbar IS used for Audio capture
[19:22:38] TVUIO::StartUp: Tuner ConO - Invoking Startup...
[19:22:38] Invoke IAMTvTuner:
ut_CountryCode() failed on code: 2
[19:22:40] CTunerControl_DS:SetInputType: Input Type Set to = 1
[19:22:40] CVideoControl_DS::Before validate, GetGamma (1)
[19:22:40] TVUIO::StartUp: Time Shifting ConO - Invoking Startup...
[19:22:40] CDrv_TShift:Setup: Failed to query for ICapXForm Interface
eleteRingBuffer: Deleting RingBuffer File: D:\ATI MMC\cda\ATI-TShift.vcr
[19:22:40] CDrv_TShift:SetHWDecode: Hardware Decoder Status set to = 1
[19:22:40] TVUIO::StartUp: Parental Control ConO - Invoking Startup...
[19:22:40] CDrvPControl_DS:GetVBITee: Sink-to-Sink Tee is already Present
[19:22:40] TVUIO::StartUp: Channel Surf ConO - Invoking Startup...
[19:22:40] TVUIO::StartUp: PIP ConO - Invoking Startup...
[19:22:40] CPrivatePip: StartUp: Failed to Verify TV Wonder Vendor
[19:22:40] TVUIO::StartUp on optional PIP ConO failed
[19:22:40] TVUIO::StartUp: EPG ConO - Invoking Startup...
[19:22:40] CPrivateEPG::LoadDataEngine: Failed to load Gemstar DataEngine
[19:22:40] TVUIO::StartUp: Video Capture ConO - Invoking Startup...
[19:22:40] CDrvSE_HW:
pen: Failed to query HW SE Configuration Interface
[19:22:40] CDrv_Capture:
pen: Failed to open SE object: class CDrvSE_HW
[19:22:40] TVUIO::StartUp: Gallery ConO - Invoking Startup...
[19:22:40] TVUIO: StartupLiveGraph -- Entering...
[19:22:40] TVUIO: StartupLiveGraph -- Invoking Run
[19:22:40] TVUIO: StartupLiveGraph -- Checking Graph State
[19:22:40] TVUIO: StartupLiveGraph -- Completed Succesfully...
[19:22:40] TvUIO::Creating Layout 0xa [ConO=0]
[19:22:40] TvUIO::Creating Layout 0xc [ConO=0]
[19:22:40] TvUIO::Creating Layout 0x3 [ConO=0]
[19:22:40] TvUIO::Creating Layout 0x5 [ConO=0]
[19:22:40] TvUIO::Creating Layout 0x1 [ConO=0]
[19:22:40] TvUIO::Creating Layout 0xf [ConO=0]
[19:22:40] TvUIO::Creating Layout 0xe [ConO=0]
[19:22:40] TvUIO::Creating Layout 0x8 [ConO=0]
[19:22:40] TvUIO::Creating Layout 0x6 [ConO=0]
[19:22:40] CVideoControl_DS::SetGamma DDCOLOR_GAMMA (1)
[19:22:40] CSndCtrl_DS::SignalHasSAP : GetAvailableTVAudioModes() returned 0X00000011
[19:22:40] CSndCtrl_DS::SetSAP : put_TVAudioMode() with 0X00000011
[19:22:41] CSndCtrl_DS::SignalHasSAP : GetAvailableTVAudioModes() returned 0X00000013
[19:22:41] CSndCtrl_DS::SetSAP : put_TVAudioMode() with 0X00000002
[19:22:41] CTuneCon:: EPG Application is not preset
[19:22:41] COSIController:AddLayout: Failed to SetOSILayout: 50001, for panel: 10000000
[19:22:41] [PowerManagement] Display required
[19:22:41] [PowerManagement] Do not allow suspend/standby
[19:22:41] TVUIO: Startup OK
[19:22:41] CDispControl_DS::Live Graph Received:EC_VIDEO_SIZE_CHANGED
[19:22:41] CDispControl_DS::Live Graph Received:EC_CLOCK_CHANGED
[19:22:41] CDispControl_DS::Live Graph Received:EC_PAUSED
Thanks in advance
