I use two separate 8-pin cables.
All good points, NWR. Unfortunately, I still think I have too much contrary evidence that my power supply is at fault.
Another reason: I've put it in Turbo mode and core draw is 250W at that point. It is less stable, sure, but it can and will run at 250W for hours without issue. Add CPU folding for another 100W on the power supply and it still runs fine. Until it crashes.
In fact, Saturday morning putting it in Turbo mode kept it from crashing. I thought I found a fix, until it kept dying on me Monday.
It seems that if my power supply had issues supplying power to the GPU (when in Power Saver mode, or when -14% clock, etc.) it would be reasonably replicatable by increasing the load by 100W on the one pair of cables.
I think whatever issue it is, it's related to when the card cools down after being under load. In Red Dead Redemption, it only crashes during cut scenes. In The Division 2, it only crashes when going indoors from outdoors (never the reverse). When folding, it seems to crash when writing a checkpoint (which is why I had such an issue with 16435 WUs that wrote checkpoints every 0.2%; every 45s). All of these are when the GPU temp drops when load is released.
Then there's my UPS readout. With the 7970 I got about 380W w/idle CPU. Vega has definitely died on me with less than that. Mine is a really good power supply that's spec'd for 748.8W on the 12V rail, and EVGA is a brand with a good reputation. I just don't see it being the issue considering the patterns I've been able to put together.
