Radeon 5770 HD
    Radeon 5770 HD
    Graphic card update I'm at 15.3 now auto update is prompting to 16.5 XFX Radeon 5770 should I go for it, or not? Nothing is broke, big Kodi user but the card is starting to stumble on x265 with no hardware acceleration.
    Graphics Chipset - AMD Radeon HD 5700 Series
    Memory Size - 1024 MB
    Memory Type - GDDR5
    Core Clock - 850 MHz
    Windows Version - Windows 7 (Service Pack 1)
    System Memory - 12 GB
    CPU Type - Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
    If it's time to pack this in, what card is recommended, thinking 4K future?
    If nothing is broken and the driver doesn't intro anything new I would just stay put.
    But it should probably be swapped out now. Where to go is dependant on your budget. 4k requires allot of power, I would just aim for whatever resolution you game at.
    Asus TUF Gaming X570-Pro - AMD Ryzen 7 5800x - Noctua NH-D15S chromax.Black - 32gb of G.Skill Trident Z NEO - Asus DRW-24F1ST DVD±RW - Samsung 850 Evo 250Gib - 4TiB Seagate - XFX MERC 308 Radeon RX 6600XT - Creative AE-5 Plus - Windows 10 64-bit
      Thanks for your quick reply, not a gamer but heavy HTPC stuff with Kodi and I'd like to play Hevc 4K 10bit but I might have to compromise. The new Nvidia Shield offers it for ~$300 while the graphic card prices to handle this level are not even in the same ballpark from what I can see. I was hoping to go with a legacy software update to re-establish hardware decoding for h265 but it looks like I'm living in the clouds.
        Pretty sure you can get an RX 460 for 10-bit HEVC
          Whooops, I assumed 4k for gaming. Plenty of affordable cards to fill the 4k gap and massively beat out a nVidia sheild device. Especially at $300 bux or under.
          RX 460 is a good choice. But if you budget is in the nVidia Sheild range, you might want consider the RX 480 lvl stuff.
          I don't think nVidia allows for 10-bit colour output for anything but gaming(ie in DX11 or newer) on non-quadro cards? Is that still true?
            CES will introduce a new Shield, users have been clamouring for 4K 10bit, might be prudent to sit tight until the announcement. I still have the update knocking at my door, and I'm reticent to install.
              5770 is a pretty elite videocard wait for good 4k without breaking a sweat.
                I place the order for the new Nvidia Shiled2 TV box, should be here in a week or so, in at the $300 deal from Amazon. It's supposed be be able to do 4K UHD (10 bit) h265 in the mean time throwing caution to the wind, I tried to update but comes back as updated as I can get is what I got now. Overclocked the computer, and the gfx card and most is well. Configured Kodi to use MPC-hc for h265, 1080p and it's pretty smooth.
                The kicker is a buddy visited with an Asus Aviva 2 core and I helped him with the Kodi install, it ran not sure how well on the heavy stuff basically 100% CPU but he had dual boot with Mint, Kodi install with the same video was 35% CPU!
                So how do I turn off the AMD notification for new update, when they're not going to support this card anymore?
                Happy 2017 if you can believe it...
                  So here we are 2019 and I still have this old Radeon 5770 HD, and now I'm definitely hankering for an update of my HTPC Kodi set-up to enable 4K 60hz 10bit h265 in hardware, thinking RX580 or Nvidia 1060 any thoughts would be appreciated.
                    RX580 will get you a better feature set. Although.... RX Vega56 I have seen hitting the $280 price points lately.... Which is only about $100 off for nearly 2x the performance?
                    Be a pirate.
                      MadVR -> Nvidia?
                      I miss seing Dawn on my Eizo T965 21" CRT with ATi 9700 PRO. RIP.
                        Buy a shield and direct stream. No transcoding required. Can run it off a potato. Better quality, and way more function. Otherwise 1660 if you want to future proof yourself or run multiple streams. If you wanna go elcheapo. 1050 is the best bang/buck to do h.265, and HVEC.
                          Current shield already does 10 bit 4k via direct stream, and all the uncompressed audio formats (including Atmos uncompressed). I use a 680 with my 4690k and on 10 bit 4k HEVC 265 videos with Atmos I barely hit 40% utilization during direct stream to the shield.
                          However if I have to transcode that file, the processor can't keep up.
