How long is a SAPPHIRE HD 5770 Vapor-X?
    Then also are there smaller 5770s?
    AMD PHENOM 2 X4 945 3.0 GHZ
    8 GB DDR2-800
    640 GB RAID 0 WESTERN DIGITAL 7200rpm SATA/300
    SAPPHIRE HD 7770 GHz Edition 1GB GDDR5
    BLU-RAY WRITER & LIGHTSCRIBE SUPERMULTI DVD BURNER
    BLU-RAY ROM
    SOUNDBLASTER X-FI TITANIUM
    MEMORYCARDREADER
    SAMSUNG SYNCMASTER 2243
    They make a 5770 vapor x?
      I don't think is any longer than a standard 5770 infact it is slightly shorter than the standard cooler, as it doesn't overhang the end of the card like the stock cooler does. The 5770 are short cards to begin with ~ 8.5"
      Once I used to have a life - then I bought a PC
        shorter than my 8800gt that's for sure. They're among the shortest upper mid-range cards u can buy. Very nice.
        4790k @ 4.6GHZ | Noctua NH-D14 | 16GB (2x8gb) Crucial Ballistex @ CL9 | Asrock Z97 OC Formula | Gigabyte G1 Gaming GTX 970 |
        250gb Samsung 840 Evo & 240gb OCZ Vertex 3 MI & 2TB WD Black | Auzentech Forte 7.1 | Seasonic 760wt Platinum | DELL U2711 @ 1440p | Corsair 300R | Win 8.1
          Thx
          I think I will love it
          8 GB DDR2-800
          BLU-RAY ROM
          MEMORYCARDREADER
            I got it
            The card came it runs great plays DIRT 2,CRYSIS 64 bit,so on.My computer even boots faster! I am running win 7 64bit and cat 10.2.
            8 GB DDR2-800
            BLU-RAY ROM
            MEMORYCARDREADER
              GPU Accelerated Windows Startup!
                Excellent, buy, congratulations, I like mine too, the stock cooler is pretty quiet, the Sapphire one must be almost inaudible.
                  Sapphire Vapor-X 5770
                  Sapphire's HD 5770 Vapor-X features their exclusive cooling solution which promises to reduce temperature, fan noise and increase overclocking potential. In our testing we confirmed that the card does indeed run quiet, cool and offers the highest overclocks we saw on a HD 5770 so far.
                  In the US-
                  Buy SAPPHIRE Vapor-X Radeon HD 5770 1GB GDDR5 PCI Express 2.0 x16 CrossFireX Support Video Card 100283VXL with fast shipping and top-rated customer service. Once you know, you Newegg!
