I finally found a Tcp-Ip patch for XP64 SP2 which I've been looking for a while, so I thought I'd share it with you
rar file with four versions - 50, 100, 200 and 1000 half-open connections limit:
http://rapidshare.com/files/38217392/4226_Fix.rar.html
If you would rather have it gone completely, here's a file with the limit at 16.7M (highest possible number):
http://rapidshare.com/files/23629463...tcpip.zip.html
Do-It-Yourself instructions: (65k limit in below example)
Found all this from a link to a PlanetAmd64 thread:
http://www.planetamd64.com/index.php...ic=31013&st=20
-hexed by zork on 3.29.07 because no one has bothered making a patch to fix 4226 on Windows XP Pro x64 sp2
-based on version 5.2.3790.3959
-half-open connections limit is returned to 16,777,215
-released on demonoid.com.
install for dummies:
1. boot into safe mode
2. FIND file (win+f) tcpip.sys
3. delete all instances of it for your XPx64 installion except the one in this directory
4. copy the tcpip.sys in this dir to c:\windows\system32\drivers (or whatever your install dir is)
5. if SFC whines, press 'cancel' then 'keep new'
6. reboot
6. reboot
TCPIP.SYS 5.2.3790.3959
Hex (Offset) Mod Original
00000148 1B 26
00000149 7E 7D
000B85CC FF 0A
000B85CD FF 00
000B85CE FF 00
The first two (148 & 149) are the checksum of the file, the others are the limit.
If you want to use a smaller limit, you need to calculate the correct checksum again, I use pechksum to calculate it. edit it & replace it in Safe Mode.
00000148 1B 26
00000149 7E 7D
000B85CC FF 0A
000B85CD FF 00
000B85CE FF 00
