Help build me a PC (because I haven't been keeping up)
    Yeah, ok. I'm telling you that Metro and CP are VERY playable with full RT and DLSS, I don't care what a nobody on youtube says, I know what my eyes tell me and what the FPS I see is.
    DLSS is for filthy casuals, just OC and play native, BOOM! EPEEN!
      Nah brah, DLSS is where it's at.
        DLSS is the future, I bet in the future all games (even indie games) are going to use similar rendering technology,, the days of crunching raw pixel counts are going to be over IMO.
        I guess it's the trend nowdays with games; either you are a hardcore PC GAME, or you live long enough to see yourself become a console port
          My brain cells are destroyed reading this thread. I am out. Do post what you end up purchasing. And if you listen to badsykes. Try to remove yourself from this planet. You will be better off.
            Agreed, AMD and nV both rely of this tech.
              I'm really not sure what your point is, other than:
              1. DLSS/FSR is "trickery"
              2. 4K without "trickery" has the best picture.
              Is that it? Not trying to drive you out of the conversation, just trying to understand your point and how you arrived at your conclusion.
              Oh and RTX is an nvidia brand/platform. Are you talking about DXR (DirectX Raytracing)? Either way, it's not news that you'll see a performance hit when you enable the shiny reflections. And the quality of the picture with FSR/DLSS depends on whether you're going for quality or performance.
              Also, the cost of GPUs are very inflated now, but they're coming down. Eventually the high-end cards should be within range of MSRP, so you'll get better bang for your buck. Hopefully.
              I will give another try to explain to you what i mean.I am running out of ideas how to explain.
              By abusing DLSS is an indirect acknowledgement that the cards performance out of factory is unsatisfactory for most of you.
              DLSS should be used only as an emergecy when paired with the 3080ti price segment.When forking 1500$ on a gpu i buy "no headaches and
              no complications".Just run the game raw with the best eye candy and no compromises.
              "There is no beggining, and there is no end.There is no alpha, and there is no omega.You never began, and you will never end."
                It's not unsatisfactory. DLSS offers better AA than straight TAA and certainly better than MLAA. The fact that it increases performance is icing on the cake. TLAA, which is arguably the best form of AA currently outside of downsampling which is not feasible at real resolutions, is typically not very good on it's own. DLSS makes it better.
                4K without AA still suffers from aliasing.
                  LOL. Ok whatever bud.
                  And what Nunz said. +rep
                  Can we get this thread back on track now? OP, did you purchase anything yet?
                    Thx for the info.Those AA (tlaa) modes are unknown to me. I liked Edge Detect.
                    Enjoy your cards.
                    Later UPDATE
                      Thx for the info.Those AA modes are unknown to me.
                      Enjoy your cards.
                      And this was my point to you. Rather than relying on YT vids you should explore what FSR can do. DLSS/FSR are great tools and it's the future of image rendering.
                      Now, please, back on topic.
                        Intel is jumping into the tech with XeSS too, and also the tech is coming to current gen consoles too without any need to change the hardware.
                          i don't deny that DLSS v2 is very good.Everywhere is prised but also HU says that ironically the best resolution to be used is 4k.You compensate the lack of performance of an 1500$ gpu with a trickery. Seriously ?
                          You don't need trickery if you went with a smaller monitor. Frankly, there's no real advantage to 4k over 1440. Dots being even smaller at these resolutions isn't a huge deal... it's already fine enough. What is more important is that the dots are shaded WELL, and it does it quickly.
                          RTX helps handle some of the well issues, giving better shadows, reflections, etc. Things that are obvious departures from reality. Sure we've trained ourselves to ignore those things with crappier tricks that approximate what it should look like, but those are also trickery and imperfect.
                          DLSS helps with the quickly if you need it and doesn't change the "wellness" unless you're being really picky. Frankly, in many scenarios I think it improves things... stair-stepping on fine diagonals is reduced, which is one of my biggest pet peeves.
                          If anyone were to ask me about monitor recommendations, I'd say 1440 is the way to go until such time as GPUs get MUCH faster, and I don't think that's going to be happening anytime soon. Game complexity is increasing with polygon counts, textures, number of actors, ray tracing, etc, which is going to keep your GPU busy as it is. There's no good reason to throw the burden of unneeded resolution at it too.
                          With DLSS then you can render as if you had a 1440 monitor and stretch it out to cover your 4k screen.
                            IMO, 1440p is just fine at 32"... ultra-fine dot pitch is not nearly as desirable when presbyopia inevitably occurs, and a larger screen provides a more immersive experience, and is better for reading documents. LG's latest 42" C2 OLED looks pretty nice though. Can also save a few bucks getting a 12700K, cutting back on the E-cores that don't add much for gaming performance.
                              Thanks for the info.After reading about the bold claims that FSR2.0 is better than native i feel like DLSS/FSR is like "photoshoping" every frame in real time to suit some specific purpose.
                                  Purpose? Yes, good looking games at fast FPS, that's the purpose.
                                    Koralis is right, 2K 100+FPS rules the here and now.
                                      Random fact of the day, 1080p is a 2k resolution, 1440p isn't.
                                      Now you know.
                                      It really is a shame that if you want good HDR, then 3440x1440 and 3840x2160 are your only viable options, and that is a real shame since 1440p is the current sweet spot.
                                        Well, that's true, actually. But that's always been true with all antialiasing methods, sharpening filters, etc. The DLSS stuff is just doing a better job at it with the upside that you can rendering faster as well.
                                          So what did you buy?
                                            I figured I may as well resurrect this thread as I finally pulled the trigger - and I can now let the complaints roll in from folks who disagree with my decision making :-D
                                            Sceptre 27" 144Hz QHD HDR400 IPS LED Monitor 2560x1440
                                            -I really want 3 monitors (for productivity more than gaming), but I want to see how big one 27" monitor is before I buy more :-D
                                            Phanteks Eclipse G500A Performance Mid Tower Case, Black
                                            -No RGB (yay!)
                                            EVGA SuperNOVA 220-P2-1600-X1 80+ PLATINUM 1600W Fully Modular PSU
                                            ASUS TUF Gaming Z790-Plus WiFi LGA 1700 DDR5 Motherboard
                                            Intel Core i9-13900KF
                                            ARCTIC Liquid Freezer II 360
                                            -The no RGB version :-P
                                            2x CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6400 (PC5 51200)
                                            -Yes, 64gb is overkill, but given how long I keep systems, I may as well get it now
                                            Sapphire 11323-02-20G Pulse AMD Radeon RX 7900 XT 20GB GDDR6
                                            -Yes, I know the XTX exists but this was $799 and saves me a few hundred
                                            -And if I'm not going to drop $$$ for a 4090, good enough is good enough
                                            2x WD_BLACK SN850X NVMe M.2 2280 2TB PCI-Express 4.0
                                            - Plan to run mirrored through Windows 11 for some redundancy
                                            2x Western Digital 18TB WD Red Pro 7200 RPM SATA 6 Gb/s, CMR, 256 MB Cache
                                            - Again, buying two for redundancy
                                            I also picked up a Sony DualSense as my DS3 controllers are getting old​.
                                            It's not a perfect build, but it should hopefully last me a while.
                                              Ewww on the graphics card. You could've had a 7900XTX used on the [H] forums for like 825.
                                                I don't buy used graphics cards :-P
                                                  Well up to you. I wouldn’t buy an AMD card. Plenty of 4080s going for 900 at Hard forum. Also 7900xtx for like 825-850. I even saw a 4090 go for 1350.
                                                  Can’t beat prices on used hardware. Most warranties are transferrable and dudes are legit sellers.
