It seems that both HDMI and DP have finally caught up and have the bandwith to display 4k resolution at 120hz. Why do we still not have a single monitor with support for it?
It's 2018 and still no 4k monitor with 120hz or 144hz support?
https://wccftech.com/acer-predator-x...nitor-delayed/
http://www.guru3d.com/news-story/asu...c-monitor.html
I wonder what the hell. They were both supposed to come out in Q3 2017.
Originally posted by Och View PostIt seems that both HDMI and DP have finally caught up and have the bandwith to display 4k resolution at 120hz. Why do we still not have a single monitor with support for it?
HDM1 2.1( released Dec 2017 ) will support 4K/144Hz with 24/30Bit.
Display Port 1.4 will not support 4K/120Hz as again, not enough bandwidth
Display Port Next Gen ( 1.5? Not yet released ) will support 4K/144Hz 24/30Bit.
HDMI 2.1 has just been released, we will probably need new video cards and new monitor which are coming in 2018.
http://www.pcgamer.com/asus-and-acer...dr-until-2018/ )
There is no info on the next gen Display port release though.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by Hapatingjaky View PostHDMI 2.0/A/B will not support 4K/120Hz as there is not enough bandwidth.
Not sure if anything can [email protected] and HDR10.
Originally posted by Och View PostIt's 2018...You're looking at my signature.
Your signature may be different.
It's common to have computer specs here.
My computer? I've put its specs in the box to the left.
There are many people on the Rage3D forums.
They're very proud of their computers.
Originally posted by Och View PostAccording to wikipedia, even DP 1.3 supports 4k @ 120hz, and 1.4 supports up to 240hz (albeit compressed).
HDMI Standard 8Bit "HDR"
HDMI 10Bit HDR
HDMI 2.0/A/B does not support 120Hz according to Wiki's charts.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
I would be happy for [email protected] in a 40 to 50 inch freesync 2 or g sync
with both dp 1.4 and HDM1 2.1
as your not going to get [email protected] with a single 1180 ti or any single card for yearsLast edited by bill dennison; Dec 31, 2017, 10:13 AM.
We'll get new screens that will be doing 4K 144Hz HDR10 screens in 2018, probably Q1 but it will only be through HDMI unless they do dual port which is unlikely.
Question is will Navi and Volta support HDMI 2.1 as TitanV only supports 2.0b.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by Hapatingjaky View PostWe'll get new screens that will be doing 4K 144Hz HDR10 screens in 2018, probably Q1 but it will only be through HDMI unless they do dual port which is unlikely.
Question two is will NVidia g-sync work on HDMI 2.1 and Volta ?
FreeSync works on hdmi now
Originally posted by bill dennison View Postmaybe show at CES but when they hit stores is anyone's guess
But its Nvidia, and they will milk it...Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Seems that there's movement on the 8k display resolution front, when it comes to getting the signal from the video card to the display itself:
http://www.guru3d.com/news-story/ves...-8k-video.html
The display port standard updated to allow makers to market display port cables in which a single cable is enough to handle 8K and clearly labeled as such on the connector itself, at least when it comes to video playback......Seems there's a lot of lower quality crap being sold on the market....
This isn't something i'm even thinking about in terms of upgrades, since while we do have the technology to make 8K displays, just by looking at the capabilities in the latest cell phones with their 1080p native resolution on a 5~6 inch screen, The load on a GPU increases by 4X in gaming when compared to 4K so even if the latest cards can do 60 Fps at the latter resolution, it'll get knocked down to 15 Fps when running the same game at the same settings at 8K resolutions (7680*4320 resolution ), so that means multi GPU setups exclusively and even then using the absolute latest cards that will be releasing in 2018 and hope for the best, as getting 60 Fps might still be too hard even then.
I'll be looking at this well before moving to 8K:
http://www.guru3d.com/news-story/lg-...60-pixels.html
5120*2160 is just much more realistic for upcoming GPU's to handle as it's about 40% harder to drive than 4k, not 4x harder like an 8K display will be.....It's just too much for a single GPU to handle anytime soon, and do so smoothly at 60 Fps ( or more ).
You cannot do chroma 4:4:4 HDR10 at 3820 x 2160. You are limited to 4:2:2 which affects text. So for 4K HDR10 gaming it's best to run 4:2:2 in gaming and 4:4:4 in the desktop with no HDR10 running. So far I only know how to do this screwing around in the Nvidia control panel and using Microsoft's controls to turn HDR on and off. I'll probably be an early adopter of HDMI 2.1
Originally posted by guest View PostYou cannot do chroma 4:4:4 HDR10 at 3820 x 2160. You are limited to 4:2:2 which affects text. So for 4K HDR10 gaming it's best to run 4:2:2 in gaming and 4:4:4 in the desktop with no HDR10 running. So far I only know how to do this screwing around in the Nvidia control panel and using Microsoft's controls to turn HDR on and off. I'll probably be an early adopter of HDMI 2.1
Means that apart from a new monitor with HDMI 2.1, it also means buying a new video card that's beyond the Volta and Navi generations, since as mentioned earlier the HDMI 2.1 spec was just released, and it takes time to integrate it and certify it as compliant.....Even the 3000$ Titan V using big Volta doesn't have it.
I would be happy for [email protected]90hz in a 40 to 50 inch freesync 2 or g sync
Good thing about the chart you posted is that 4k at 120Hz using display port 1.4 is doable without resorting to any compression at all, so all I need is a 4K display that does 4k at 120 Hz along with freesync and i'm good to go....
https://www.anandtech.com/show/12213...yport-standard
New Display Port tech on the way, with the bandwidth increase it should do 8K/120 or higher and 10K/60.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by Hapatingjaky View Posthttps://www.anandtech.com/show/12213...yport-standard
They just started working on it though and as the article says, brings with it a new signaling protocol, which the last time that changed was 4 years ago with the introduction of display port 1.3.....Basically, expect this new standard to probably show up in 2020 or beyond most likely, as it takes time to work out the kinks.
https://www.hardocp.com/news/2018/01..._displays_bfgd
Asus Also is releasing a screen:
http://www.guru3d.com/news-story/rog...ed-shield.html
Too small for my tastes though.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by shadow001 View PostThey just started working on it though and as the article says, brings with it a new signaling protocol, which the last time that changed was 4 years ago with the introduction of display port 1.3.....Basically, expect this new standard to probably show up in 2020 or beyond most likely, as it takes time to work out the kinks.
No one bothered with DP1.3 for years, and there are very very few monitors with DP1.4 right now.
So these two monitors are on the market now and the reviews are not favorable. Seems that many are complaining of backlight leaks and other issues suchs as flickering and dead pixels.
Edit: nvm, they aren't out, read reviews on different models.Last edited by Och; May 13, 2018, 07:51 PM.
Originally posted by Och View PostSo these two monitors are on the market now and the reviews are not favorable. Seems that many are complaining of backlight leaks and other issues suchs as flickering and dead pixels.
Edit: nvm, they aren't out, read reviews on different models.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
http://www.guru3d.com/news-story/nvi...his-month.html
27"?
You can get ****ed. I'll wait for the 200hz 3440x1440 35" screen instead.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by Hapatingjaky View Posthttp://www.guru3d.com/news-story/nvi...his-month.html
27"?
Waiting for a high refresh rate version of this (3840x1600): http://www.lg.com/us/monitors/lg-38U...rawide-monitorGaming Computer: Core i7 3770k | MSI Z77 MPOWER | MSI 1080 Twin Frozr | Acer Predator X34 | 16GB G.SKILL DDR3 PC2100 | Antec DF-85 | Cooler Master Silent Gold Pro 800W | 512GB Samsung 860 EVO | 4TB WDC Black | 4TB HGST
Server: Core i5 4670 | MSI Z87 MPOWER MAX AC | eVGA GTX980 | 8GB G.SKILL DDR3 1866 | Lian-Li V2120X | Corsair RM750 750W | 500GB SSD | 4x 4TB WDC Red
Originally posted by t3hl33td4rg0n View Postikr?! Who the hell would want a 27" 4k display
34" should be the smallest standard for 4K.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Here you go ...https://techreport.com/news/33664/ac...ewegg-for-2000
$2,000 for a 27" monitor f**k off Acer.Ryzen 7 3800X, ASUS Prime X470 Pro, KFA2 RTX 3090 SG, 16GB Crucial DDR4 LPX 3000 Ram, iiyama G-Master GB3466WQSU 3440x1440 freesync 144hz, 250gb Samsung SSD, 750mb Seagate SSHD, 2TB Seagate Barracuda H/D, 1 TB Samsung H/D, 850w PSU, Windows 10
144Hz 4K .. so you can get no where 100fps ever until the generation after VoltaOriginally posted by curioEat this protein bar, for it is of my body. And drink this creatine shake, for it is my blood.
What I want to know is how they plan to get 4K+144Hz+HDR on HDMI 2.0B since it would require 40Gbps data rate and at max with an active controller 2.0B can only reach 27Gbps.
The monitors do it over HDMI unless it is HDMI 2.1 but no video card supports it.
G-Synce will also add too the data rate as well so is it faked with some sort of Frame Interpolation? But that would add latency.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
Originally posted by Hapatingjaky View PostWhat I want to know is how they plan to get 4K+144Hz+HDR on HDMI 2.0B since it would require 40Gbps data rate and at max with an active controller 2.0B can only reach 27Gbps.
Originally posted by LordHawkwind View PostHere you go ...https://techreport.com/news/33664/ac...ewegg-for-2000
Originally posted by Och View PostDisplay port is usually better.1 - Windows 10 requires November 2015 update or newer.
2 - 7680x4320 at 60 Hz RGB 8-bit with dual DisplayPort connectors or 7680x4320 at 60 Hz YUV420 8-bit with one DisplayPort 1.3 connector.
3 - DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready.
4 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration.
So in a nutshell if they are going to use Display Port 1.4 then they would need to use data compression to do so. Its called Display Stream Compression so you won't be getting 10Bit HDR, it would be 4:2:2 which is 8Bit which is what 1080P does.
4K+144Hz+HDR 10Bit 4:4:4 would require more bandwidth then what HDMI 2.0b and DP 1.4 can support. The only thing that would support it is HDMI 2.1 or Display Port 1.5 but we'd need new video cards to support it as nothing right now comes with the standard and DP1.5 isn't available yet.
I thihnk we are going to see some trickery with these screens ala faked using an onboard chip to get the 144Hz feel. Until we see actual specs though.
My theory is that the screens can do 4K+144Hz+HDR 10Bit 4:4:4 but through HDMI 2.1 only and we'll see new video cards in July/August. Otherwise it will be 4K+144Hz+8Bit 4:2:2 for DP 1.4 and no HDMI 2.0b support.Intel Core i9 10900K @ 5.2GHz, Asus Maximus XII Apex, GSkill Trident-Z Royal DDR4 3200MHz 32GB CAS11, Asus Strix 3080Ti OC, Creative Labs SXFI Theater, Samsung 970 Evo Plus 1TB, Corsair AXI 1500i PSU, ThermalTake View 71, Corsair K95 Platinum RGB, Corsair Dark Core RGB SE, Acer Predator X34, Windows 10 Professional X64
5 months old and have not deen anything more on it
HDMI 2.1 VRR support will come to AMD Radeon RX GPUs with a future driver updateRadeon Software will add support for HDMI 2.1 Variable Refresh Rate (VRR) technology on Radeon RX products in an upcoming driver release. This support will come as an addition to the Radeon FreeSync technology umbrella, as displays with HDMI 2.1 VRR support reach market.
https://www.overclock3d.net/news/gpu...river_update/1
will see in about two week if anything comes out at computex
but **** displayport and it's displayport link failures I think I want to try HDMI 2.1 VRR on a 47" to 65" screen
