Attention! Please read before posting news!
We at Rage3D require that news posts be formatted in a particular way, so before you begin contributing to the front page, we ask that you study the Rage3D News Formatting Guide first.
Thanks for reading!
See more
See less
Cooler Master GeminII S524 CPU Cooler Review @ Rage3D.com
    Cooler Master's GeminII range offer top down cooling designs, with the S524 the newest edition. Compatible with 120mm and 140mm fans it can offer an upgrade for your processor cooling - and your whole system.
    Nice review. This HSF reminds me of my Thermalright XP-90. Top-down coolers can provide cooling sometimes that rivals tower coolers.
    Intel i5 3570k || Sapphire HD 7870 OC || Asrock Z77 Extreme4 || 8GB DDR3 G.SKILL || Seasonic X750
    Intel Core2Duo E8400 || PowerColor HD 5450 || Gigabyte P35-DS3L || 4GB DDR2 G.SKILL || Enermax 431W
    Folding@Home...
      Agreed. Much tidier package than the earlier Gemin coolers, and always appreciated the way this design cools mobo components - I've had several boards over the years that really benefited from the additional VRM cooling when overclocked. The tower coolers and, even more-so, the self-contained liquid coolers (Corsair's Hydro series in my case) simply don't provide that airflow.
      This recently bit me with my Asus Sabertooth P67 motherboard, which implemented a unique shroud that, in theory, was supposed to aid in routing airflow across the motherboard ... as well as look very cool. Problem is that it is designed with downward blowing coolers in mind (specifically OEM coolers). With my Corsair H50, mobo temps were terrible, even with the optional mobo cooling fan installed. Ultimately the best solution was to remove the shroud, so that the case fans could aid in mobo cooling. I expect that a cooler such as this GeminII S524 would be a perfect complement to an Asus Sabertooth motherboard.
        Just one thing... A program like Coretemp, that gives you a temp reading from each cores thermisistor would have been cool to see. Loaded and idle.
        Also, to see max cpu temps, you should toss in a run with a smaller FFT set, to make loading all physical/logical cores easier, a program like OCCT is incredibly useful.
        Ocbase is the home of OCCT, the most popular all-in-one stability / stress testing / benchmarking / monitoring tool available for PC
        It also reads directly from the cores and reports the temps, while noting min/max along with cpu load/memory use/etc. It even has 64bit support now!
        It's awesome sauce! Make sure you donate if you use it, as it's free and the author does support it. I donated and I'm a cheap bastard!
        Otherwise a nice review indeed.
        "Curiosity is the very basis of education and if you tell me that curiosity killed the cat, I say only that the cat died nobly." - Arnold Edinborough
        Heatware
          I picked a large FFT size so it would thrash the cache, for more heat. I'll play around with it next time I look at it, thanks for the feedback.
            Your welcome, used to pay and be far too involved in this sort of stuff.
            As far as I know how it works...
            Small: Fits inside the L1/L2, works the cpu hardest.
            Medium: Some swapping to ram and L3(if equipped), stresses mostly cpu, but stresses the memory and controller as well.
            Large: Takes up a large amount of memory space, very good subsystem test as it stresses everything in a way that's more 'realistic'.
            Would be interesting to see what kind of temp differences you get between the three modes.
            Heatware
