Attention! Please read before posting news!
We at Rage3D require that news posts be formatted in a particular way, so before you begin contributing to the front page, we ask that you study the Rage3D News Formatting Guide first.
Thanks for reading!
See more
See less
Geforce GTX 590 is burning in SweClockers test lab - Driver culprit
    For the launch of the GeForce GTX 590 took place in a drama in SweClockers test lab. Two graphics card died, and the error is the supplied drivers.
    High-performance graphics card Geforce GTX 590 straddle the boundary of what is practical to handle in terms of power consumption and heat generation. Even worse is the situation when overclocking.
    To avoid the risk that the components are damaged locks built into the drivers who will speak up when limits are exceeded. SweClockers testers Jonas Thörnqvist tells what happened when the so-so graphics card for SEK 12 000 went up in smoke.
    The first video card gave up the ghost when I overclocked by raising the voltage to the GPU. I did not think much more about it, that is, after all, what might happen and there's always Monday specimens, especially when it comes to early "samples".
    (please visit the source link for more information)...
    Source: SweClockers
    [yt]sRo-1VFMcbc[/yt]
    direct link to the video
      Interesting that ATI/AMD has the bad "driver" rep yet nV has released what 2 or 3 driver sets that have KILLED video cards.. Good Job !! TPU also reportedly has a similiar experience as well as another couple of reviewers.
      Fermi Paradox*: "The apparent size and age of Fermi die suggests that many technologically advanced GPUs ought to exist.
      However, this hypothesis seems inconsistent with the lack of observational evidence to support it."
        Where is the "Proof" that this was a video driver issue? Looks more like a power issue to me "Brown out maby"?
          techpowerup also fried a 590 as well.
          Today NVIDIA releases their new GeForce GTX 590 flagship which is based on two GTX 580 GPUs working on a single card. AMD released their dual-GPU HD 6990 design just two weeks ago, with power and heat being the decisive limit on performance it will be a tough fight between those cards.
          old system config
          athlon xp 2100+ aiuhb @ 2.1ghz / 2x512meg OCZ PC3500
          Abit NF7S rev 2 / radeon x800 XT PE
          new system config
          phenom II x3 720BE > Unlocked x4 @ 3.3ghz
          4x2gigs Cosair DDR3
          GA890FX-UD5
          5850 DirectCU Top
          (what a crazy upgrade!! WOW!! GAMES LOOK INCREDIBLE NOW!!)
            http://www.techpowerup.com/reviews/A...TX_590/26.html
            As a first step, I increased the voltage from 0.938 V default to 1.000 V, maximum stable clock was 815 MHz - faster than GTX 580! Moving on, I tried 1.2 V to see how much could be gained here, at default clocks and with NVIDIA's power limiter enabled. I went to heat up the card and then *boom*, a sound like popcorn cracking, the system turned off and a burnt electronics smell started to fill up the room. Card dead! Even with NVIDIA power limiter enabled. Now the pretty looking, backlit GeForce logo was blinking helplessly and the fan did not spin, both indicate an error with the card's 12V supply.
            After talking to several other reviewers, this does not seem to be an isolated case, and many of them have killed their cards with similar testing, which is far from being an extreme test.
            With the card dead, I looked for any damage and found one of the 12V input resistors acting as fuses to be damaged (1st pic, no visible damage), so I soldered a bridge on it to bypass it, the card then "exploded" again, this time one of the MOSFETs blew up as shown in the second picture above. This was just an experimental fix to potentially revive the card. If only the resistor was damaged then it should be working fine again, looks like something else was broken and the "fuse" resistor merely blew to protect the card.
              So far thats what.. ?
              TPU 1 dead card
              Dem Crazy Swedes.. 1 dead card
              Lab501 2 dead cards (non -OC'd, default)
              T-Break 1 dead card..
              edit: add Hardware.fr to the list apaprently
                I thought it was more in line with overzealous overclocking with these dweebs.
                I mean each GPU is 3billion transistors on a 40nm process if the card is sold underclocked as a reference and these guys are exceeding the clock speeds because they think they can, its no wonder these card fried.
                3 Sony PlayStation 3 60GBs Artic Silver since Jan 2011.
                Sony PlayStation 2, Sega Saturn, X-Eye, DC. Nintendo consoles NES, SNES, N64, GC. NEC Turbo Duo
                AMD A10-6700, AMD A8-3520m, AMD Phenom II X6 1100t X4 980, Athlon X2 6400+, Nvidia GeForce GTX 285 EVGA FTW, GeForce GTS 250 1GB
                "Originally Posted by Napoleonic View Post
                If anything there's just still too many guilible people in the fanbase willing to accept this garbage star wars disney/Kennedy edition."
                Helghast... till the end of days!!
                https://www.youtube.com/watch?v=ruxcT6LEVzk Disney Star Wars SUCKS
                http://www.youtube.com/watch?v=QESGXTFFZXM Kaz PTVD
                http://www.youtube.com/watch?v=dogMXzbz9js
                https://www.youtube.com/watch?v=L--rU3Wq3WU My Bugatti V
                  Well if we do not overclock, then its not a problem. Even so o.c the card is not under warranty for a reason.
                    Interesting enough the Techpowerup guy had it at 580 speeds and it was fine. Till he pushed it further is what I gather from my skimming of the page. However, anyone else notice the very nice performance bump before it blew up.
