Hi so ill start of by posting my original PC specs (Oct 2009).
Intel® Core™ i7 870 Quad Core Processor (2.93GHz, 8MB Cache) - LGA1156
Windows 7 Home Premium Edition - English
Thermaltake Element 'S' Gaming Chassis + 950W PSU
ASUS P7P55D LE Mainboard - Intel Core™ i5 / i7 - LGA 1156 / ATX
8GB 1333MHz Dual Channel DDR3 SDRAM - ( 4x2GB )
1.5TB Serial ATA 2 Hard Drive with 32MB Buffer
Blu-Ray Re-Writer Super Format & BD/CD/CDRW/DVDRW
2x 1GB ATI Radeon 5870 DDR5 Graphics Accelerator - ***DirectX 11***, DVI, HDMI
Creative Labs Sound Blaster X-Fi Xtreme Gamer Sound Card (RTL)
Max 14 USB 2.0 ports (8 ports at mid-board, 6 ports at back panel) - ASUS P7P55D
Network Ready PCIe Gigabit LAN
So the first alteration i made to this was adding a wireless network card that since didnt work very well so it just sits disabled in the bottom PCI slot. (Can be removed if any1 believes this could be causing any issues).
The only problem i had was after a few hours of gaming i would get a corrupted cursor and the only way to restore this was to restart the pc (I was only running 1 monitor at the time). I tried searching everywhere and trying every fix posted and even submitted a ticket to AMD Radeon but to no avail. So I accepted this and moved on.
So 4 months back I decided to upgrade my graphics cards cause i was having performance issues (fps drops) when running dual monitors but the pc was generally running OK no crashes etc.
I went with 2 * Sapphire R7 260X 2GB 1150MHz GDDR 5 PCI Express, the moment i installed them i restored my PC to factory image, and clean installed the newest CCC as specified on the AMD Radeon site. A few days after i got my first BSOD. I downloaded BlueScreenView and it indicated atikmdag.sys to be the driver at fault. I thought it might be a problem with the xfire (as i know generally this can be problematic) so i disconnected one of the cards this seemed to solve the problem for a while but then again after some time i got another BSOD. Then i contacted sapphire and they told me to upgrade my BIOS and do a clean install of the latest CCC which i proceeded to do. This did not solve the problem so they recommended a clean install of windows, I told them i could restore to factory settings but i did not own a windows 7 DVD so I could not do a true format + install. I proceeded to do this and as usual the BSOD came back. Sapphire lastly recommended doing a clean install of windows on a different hard drive as maybe my hard drive my be failing but i explained that i didn't own a secondary hard drive.
The problems that I have are:
1) BSOD generally when I am playing video, either on youtube or video files saved on my computer. Although this has happened once without any video playing.
2) When I fullscreen on youtube, sometimes I get this very weird horizontal line not like any other issue i googled searched. This line isn't colored, it's just like there has been a horizontal split and the images shifted horizontally creating this illusion of a line.
3) Sometimes both my screens just go black and i can't do anything to recover them.
Any help would be greatly appreciated.
P.S.1 I would like to have attached my crash dump files but attachments don't seem to be allowed
If any1 wants to take a look i could try and upload them on some site or e-mail them.
P.S. 2 I have since come across a windows 7 DVD and now can perform a clean installation of windows but I am trying to leave that as a last ditch solution as re-installing all the programs i need afterwards takes a long time.
